Old 06-09-2009, 12:09 PM   #1
Grounding on Natural Gas Line
Hello,
Excuse me in advance if I use the wrong terminology. Yesterday I had the cable guy in my furnace room doing some work and he pointed to a ground wire that was attached to a metal pipe that is part of the natural gas line. He said this was very dangerous as if the house was hit by lightening the house could explode. I called the builder of my house and told him what the cable guy said and he said flat out that he was wrong and that it was completely safe and had been inspected by the city inspectors when it was built.
Needless to say I am concerned by the suggesting of an explosion! Can anyone offer an opinion as to whether having a ground on the NG pipe is dangerous or not.
Thanks!
HobieCat is offline   Reply With Quote
Old 06-09-2009, 12:15 PM   #2
DIY'r
ScottR's Avatar
The cable guy was right. It should be connected to a water pipe if anything. If it's part of your house's grounding system, then there are more specific requirements as to where it's connected (but never to a gas pipe, by code).
What does that wire connect to? Is it part of the electrical system, or phone, cable, etc?
I don't know that it would cause the house to explode.. There's not enough gas in the pipes in your house to cause a huge explosion, but I suppose it could start a fire. Probably not.
My concern would be that if it's a copper grounding clamp (or copper anything) on steel gas piping, you could get galvanic corrosion of your gas pipe, and then a gas leak.
ScottR is offline   Reply With Quote
Old 06-09-2009, 12:29 PM   #3
Thanks for your reply.
I'm not sure what the wire is connected to. It is a thick multi thread copper wire which is clamped to the metal gas pipe and then it ends.
Old 06-09-2009, 12:29 PM   #4
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
In this state and few others (mostly in the south) you have to bond the gas line to the grounding electrode system with a #6 if CSST pipe is being used.
It needs to be bonded before it enters the house though.
wirenut1110 is offline   Reply With Quote
Old 06-09-2009, 12:58 PM   #5
Thanks for the feedback.
Who do you suggest I call, an electrician or a building inspector to advise me?
Old 06-09-2009, 01:24 PM   #6
Licensed electrician
Can you follow to see the other end of this wire? Quite possibly it is just bonding the gas line to the water lines and the panel.
Old 06-09-2009, 02:33 PM   #7
J. V.'s Avatar
The cable guy was wrong. Partially.
Old 06-09-2009, 02:46 PM   #8
DIY'r
ScottR's Avatar
I thought you never bond to a gas pipe inside a house.. ?? When is it allowed/a good idea?
Old 06-09-2009, 02:55 PM   #9
My License Ain't 4 Sale..
You never use a gas line as a grounding electrode. However, if it is metal it is required to be bonded. Some jurisdictions consider the gas line bonded by the physical connection it has with an appliance, such as a stove with electric ignitor. There is no harm in jumping a bonding wire to the metal gas pipe. I prefer this than actually relying on a plumbing connection to affect the bond.
A high voltage surge running along a gas line is not going to make it explode.
Old 06-09-2009, 03:27 PM   #10
DIY'r
ScottR's Avatar
OIC.. My mistake. I half-remembered the first part, and took it too far.
Old 06-09-2009, 11:59 PM   #11
Cable guy was probably wrong.
All metal piping must be bonded to the electrical system.
If it was a stock installation and the wire goes to the panel or is jumpered to/from the water piping, it's a good installation. If someone just tapped it for a ground (like a cable guy ) it is wrong.
220/221 is offline   Reply With Quote
Natural gas line to garage SxS Plumbing 11 08-27-2010 07:08 PM
PVC line on natural gas line for BBQ Nikroo Plumbing 28 05-13-2009 10:01 AM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
moving incoming power line and grounding rod amakarevic Electrical 3 07-29-2008 12:24 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
