Grounding Multi-circuits In Multi-gang Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 01:57 PM   #1
Grounding multi-circuits in multi-gang box
Are the grounding conductors to remain separate for each circuit within a multi-gang box (plastic) to avoid creating ground loops? Or grounding conductors should all be tied together within any enclosure regardless of whether they serve separate circuits, and despite being tied together at the ground bar in the service panel?
sixspeed is offline   Reply With Quote
Old 07-24-2012, 04:16 PM   #2
Rewards Points: 1,442
All of the ground wires are tied together. With additional short lengths (pigtails) to devices (switches, receptacles) in the box and to the box itself if metal.
The Following User Says Thank You to AllanJ For This Useful Post:
sixspeed (07-25-2012)
Old 07-24-2012, 06:11 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
That is NOT how ground loops are formed... And you need to splice all the grounding conductors together and bond the devices.
Sub Panel Grounding bar bmancanfly Electrical 12 05-24-2009 03:07 PM
Grounding for different circuits in the same box? epeterson777 Electrical 23 03-19-2009 09:04 PM
Grounding circuits in barn businmike Electrical 2 06-01-2008 10:22 AM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 07:37 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 06:55 PM
