Grounding A Middle-of-the-run Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 07:06 PM   #1
Rewards Points: 1,062
Question
grounding a middle-of-the-run switch
does a middle-of-the-run switch always have to be grounded ? i have installed a couple without, i.e. the ground in is just spliced with the ground out w/out connecting the ground screw on the switch, and it works fine. however, the book shows to always do it.
Old 10-19-2008, 07:16 PM   #2
Electrician
Art 404.9(B) requires all snap switches to be effectively grounded and a means to ground a metal faceplate, whether or not a metal faceplate is used or not.
chris75 is offline   Reply With Quote
Old 10-19-2008, 07:20 PM   #3
Electrician
Yes, you need to ground the switch if the switch has a ground terminal on it and the box has a ground wire in it.
There are a few exceptions.
If the switch is installed in a metal box, the box is adequately grounded, and the switch is a self grounding device, then you do not have to install a grounding pigtail to the device.
If the switch face plate is non-metallic and is secured to the switch using non-metallic screws, then you do not have to install a grounding pigtail to the device.
Your statement about the switches not having a ground connected and still working fine is true, but that is because the ground wire is not needed under "normal conditions". The ground wire is there for safety. It is intended to carry fault current under "emergency" conditions.
edit: I beleive Chris is correct and I am wrong about the faceplate exception, my apologies, I take it back.
EBFD6 is offline   Reply With Quote
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
