Grounding Method - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 10:47 PM   #1
Rewards Points: 150
Grounding Method
Hey guys,
I've come across some metal 4x4 boxes that were fastened to concrete or steel. These boxes weren't grounded so I wanted to attach a grounding pigtail using the tapped hole in the back of the box. If I install the grounding screw it hits the concrete or steel almost immediately and the wire is not tight to the box.
What do you guys do when you come across this?
These are some of the things I've done:
1. Mark the hole and remove the box and drill a hole for the grounding screw to fit into then reinstall box
2. Install a different box (one with the raised threaded hole)
3. Use grounding clip that attaches to the front edge of the box
Sometimes these things are easier to do than at other times depending on the conduit/box layout.
Is it acceptable to shorten the grounding screw with the screw cutting function of my wire strippers then install the grounding pigtail?
Steelhead is offline   Reply With Quote
Old 02-04-2009, 10:50 PM   #2
Grounding clip. Works great. Its the green thing in my last thread.
Not sure about the screw, Im sure it wouldn't hurt anything, but it does void the ul rating.
rgsgww is offline   Reply With Quote
Old 02-04-2009, 10:59 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 234
I cut the screw flush with the box.
Old 02-05-2009, 09:03 AM   #4
Registered User
Termite's Avatar
Grounding clip.
Old 02-05-2009, 11:06 AM   #5
DIYer
There are no such thing as UL listed ground screws. We went through this in another thread.
Gigs is offline   Reply With Quote
Old 02-05-2009, 11:12 AM   #6
Rewards Points: 80
Washers?
Old 02-05-2009, 12:06 PM   #7
Come to think of it, there is no rating.
Grounding for new meter at detached garage steve37887 Electrical 1 10-22-2008 03:17 PM
Grounding light box n0c7 Electrical 10 10-06-2008 04:20 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 08:31 AM
Grounding electrode at subpanel Randell Tarin Electrical 18 02-01-2008 10:05 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
