Grounding A Metal House. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2008, 06:01 AM   #1
Grounding a metal house.
What is the acceptable method to ground/earth ground a new metal house in 2008. They didn't install an Ufer ground when they poured the basement floor.
RobertS is offline   Reply With Quote
Old 03-11-2008, 06:07 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
What parts are metal?
For 1 & 2 family dwellings a Ufer is not yet mandatory in NYS as it is under the 2008 NEC.
Old 03-11-2008, 06:13 AM   #3
The main frame is metal I-beam, The roof, and sides are metal, and it has metal studs inside on a plywood floor. I-beams, and studs are all 6" if that maters. At this point he is installing MC boxes, and planning to run romex. I'm not touching this one. I told the home owner to have his electrician come over, and show him what he needs. So far he has waisted about $1000 on electrical stuff.
Old 03-11-2008, 06:17 AM   #4
This would be a typical grounding/bonding scheme. Just make sure the (structural) building steel is bonded correctly.
Are you doing this or are you having a contractor do it?
Old 03-11-2008, 06:25 AM   #5
The home owner is a fool, and a constant argument I'm not touching this one. He is installing boxes for MC/BX and is planning to use Romex. He found the boxes for free some where. An Ufer, isnt manditory but it would have been a good idea, and cost effective.
Old 03-11-2008, 06:56 AM   #6
Absolutely.
Old 03-11-2008, 10:04 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
That's a lot of romex to tear out after it fails inspection.
Old 03-11-2008, 10:50 AM   #8
Why would it fail inspection?????
Old 03-11-2008, 08:58 PM   #9
Union Electrician
goose134's Avatar
I don't use Romex, but can't you use take-all connectors in this type of application? Speedy, I think the worry is that the boxes have 1/2" KO's and not romex hits.
goose134 is offline   Reply With Quote
Old 03-11-2008, 09:02 PM   #10
RX clamps, 1/2" ko's and connectors, whatever. It's still legal.
I think Maintenance is saying NM cable would not be legal. This is wrong.
As long as it is installed properly; grommets, etc, then it is perfectly legal. Not entirely desired, but legal.
I have done several jobs (working for others) with ALL metal studs and framing with NM cable. It's a real P-I-A but it is doable.
Old 03-11-2008, 09:22 PM   #11
Electrician
Here ya go.
chris75 is offline   Reply With Quote
Old 03-11-2008, 09:28 PM   #12
Union Electrician
goose134's Avatar
My mistake, I thought it was the boxes he was worried about.
Old 03-11-2008, 09:37 PM   #13
Originally Posted by chris75 View Post
Attachment 2772
Here ya go.
See that. Even Mike Holt approves.
Old 03-11-2008, 10:21 PM   #14
Electrician
The NM was a bonus in that picture...
Old 03-12-2008, 07:17 AM   #15
I was thinking of the guy pulling romex directly through the metal studs and all that plastic sheathing getting sliced up. Sorry. I read more into it than was there.
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Grounding a non-grounded metal blower o2barockstar Electrical 1 10-22-2007 08:53 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
