Grounding Metal Boxes And Outlets - Confused By Something Simple - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 08:16 AM   #16
Rewards Points: 2,516
For basement switch in EMT I grounded the box and the switch.
Grounding Metal Boxes and Outlets - Confused by Something Simple-100_8316.jpg   Grounding Metal Boxes and Outlets - Confused by Something Simple-100_8317.jpg
hammerlane is offline   Reply With Quote
Old 06-14-2012, 09:24 AM   #17
Originally Posted by ALFisher
... Now, one day, I learn why (other than the code says so) connecting the two egcs is required rather than connecting both to the box, but I leave that for another day.
There is supposed to be more secure contact between the conductors if they are twisted together and crimped or nutted than relying on the grounding screw to hold them tight as it may vibrate loose. If the screw loosens or one conductor slipped out from under the screw, continuous ground would be lost.
Same idea as not double tapping a breaker or Putting two hots on one device screw.
A conductor may be looped around a screw on its way elsewhere but if it is cut it must be properly terminated.
Evstarr is offline   Reply With Quote
Old 06-14-2012, 10:20 AM   #18
Rewards Points: 204
The tape around the device makes me laugh. But hey, whatever floats your boat.
Old 06-18-2012, 03:49 PM   #19
Why is this funny? I have seen several folks do this in metal boxes.
ALFisher is offline   Reply With Quote
Old 06-18-2012, 04:00 PM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Yeah, and its funny to come across.
Old 06-18-2012, 04:22 PM   #21
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
I do not like using 2 connections under a ground screw, not sure it meets code. I would leave that bare ground long, wrap on the ground screw and continue to the recep.
I only use tape on a receptacle when I install a a GFCI recep. in an old (small) metal box. No reason in the 4" box you have.
I assume you are using the EMT as a sleeve and not running NM all the way.
Coastal South Carolina
Old 06-18-2012, 04:27 PM   #22
A "Handy Husband"
rjniles's Avatar
Another point to the OP:
If you run the bare ground to the receptacle and try to use a self grounding receptacle to ground the box, you lose the box ground if you pull out the receptacle. Or down the road if someone changes the self grounding receptacle to a standard non- grounding, you lose the ground to the box.
Old 06-18-2012, 04:40 PM   #23
E2 Electrician
It's a violation...
The Following User Says Thank You to stickboy1375 For This Useful Post:
rjniles (06-18-2012)
Old 06-18-2012, 04:41 PM   #24
E2 Electrician
You can't bond the box via the device, but you can bond the device via the box... What you speak is a code violation so its a moot point.
Old 06-18-2012, 04:48 PM   #25
A "Handy Husband"
rjniles's Avatar
I was trying to explain the rational behind the code.
Old 06-18-2012, 04:52 PM   #26
E2 Electrician
Why not just stick to the facts? The box must be bonded....
Old 06-18-2012, 04:55 PM   #27
A "Handy Husband"
rjniles's Avatar
You are getting a little testy
Old 06-18-2012, 04:57 PM   #28
E2 Electrician
Absolutely not... black and white words.... no need to add emotion to that.
I was trying to keep it simple and clean...
Old 06-18-2012, 05:43 PM   #29
That piece of tape only cost a nickel.
EMT is a sleeve for the vertical drop.
Old 06-18-2012, 05:46 PM   #30
Glad you are amused.
I don't know where you fish but water typically floats mine.
sealing boxes and outlets 4just1don Electrical 1 02-01-2012 05:29 AM
Replacing old outlets (grounded vs none) Sonya_ Electrical 14 10-07-2011 11:37 PM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Upgrading 2 prong(ungrounded) outlets to 3 prong(grounded) AdamsBurr Electrical 14 06-24-2011 09:13 AM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
