Old 12-01-2012, 09:23 PM   #16
Grounding With Metal Boxes
I just want to prove a point to someone. I think we agree it isn't up to code and not the proper way, but why is it not ok? What is the problem with it? There are probably millions of houses grounded this way. Ignore that the wire should be further in the box, that's a given.
cre10 is offline   Reply With Quote
Old 12-01-2012, 10:14 PM   #17
A "Handy Husband"
rjniles's Avatar
The problem is it does not meet code. What are you trying to prove?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-01-2012, 10:25 PM   #18
E2 Electrician
stickboy1375's Avatar
Why do you think it's okay? The ground wire is squeezed between the connector, no way is this going to be a low resistance path for a ground fault.
Old 12-01-2012, 10:29 PM   #19
When did I say it was ok?
I'm asking for facts as to why it is not ok, not "because it isn't code".
How many millions of houses do you think are wired this way?
You're an all knowing professional that does everything perfect and up to code so explain it.
Old 12-01-2012, 10:30 PM   #20
E2 Electrician
I just did, what else do you want?
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (12-01-2012)
Old 12-01-2012, 10:57 PM   #21
Electrical Contractor
If the washers were not removed from the receptacle, then it is not grounded properly anyway.
With a loose ground connection, a high current fault could sit there and arc, creating a fire.
Just because they did it that way years ago, does not mean it was safe then.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
cre10 (12-01-2012)
cable line grounding amakarevic Electrical 56 05-15-2012 10:22 PM
Question on Grounding 3-Gang Metal Box GeorgesAA Electrical 3 04-14-2012 01:43 PM
Grounding using plastic boxes? gone_fishing Electrical 9 01-05-2009 12:36 AM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 06:54 PM
grounding electrical boxes handifoot Electrical 5 05-07-2006 12:40 PM
