Grounding Metal Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 05:56 AM   #1
Rewards Points: 77
grounding metal boxes
I am building new in MN. I ran all 12ga wire for 20 amp circuits, some to metal boxes and I have some questions
Will the boxes be grounded by a receptacle?
By a switch?
If I have to use a wire and screw to ground the boxes, can I use 14ga?
bkvanbek is offline   Reply With Quote
Old 06-28-2011, 06:08 AM   #2
Rewards Points: 1,548
As usual, connect all ground wires coming into the box. Use an additional short length (pigtail) to reach each receptacle or switch green ground screw.
Method 1. Connect ground wire to receptacle or switch as usual. Get a special clip (sold separately for that purpose) to squash between the tab of the receptacle yoke and the box as you screw the receptacle in place. One clip per box.
Method 2. Use an additional bare pigtail to connect to a screw into the box (or to a special clip that fits over the edge of the box). Note that the screws that hold cable clamps at the back of the box cannot be used because they can't be tightened enough without damaging the cables.
Method 3. Instead of connecting ground wires to the receptacles, connect just one ground wire to the box. Use the special clips, one per receptacle (and switch) when installing these in the box.
You need 12 gauge ground pigtails for a 12 gauge 20 amp circuit.
Using green wire nuts with a hole in the small end, one of the incoming ground wires can be left longer and go through the small hole and then be connected to something, so one fewer pigtail is needed. Two ground wires cannot go through the small hole because screwing on the wire nut will chew up the wires.
Building Planter Boxes kimberland30 Landscaping & Lawn Care 1 05-15-2009 10:19 PM
Grounding using plastic boxes? gone_fishing Electrical 9 01-04-2009 11:36 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 05:54 PM
grounding electrical boxes handifoot Electrical 5 05-07-2006 11:40 AM
