Grounding A Light Fixture With No Ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 08:00 PM   #1
Question
Grounding a light fixture with no ground wire?
Hi there,
I hope someone will be able to help with this...
I bought a this pendant light fixture that is plug in, and I plan to remove the end of the cable, and hardwire it.
I will connect the ribbed wire to the white wire, and the smooth wire to the black wire in the junction box.
Here's the problem: the light is a polar plug but only has 2 wires in it, and I'm not sure how/if I can ground it.
Is there something in the fixture that I can connect the junction box's grounding wire to?
If this isn't possible, is it okay for me to go without grounding?
Thanks,
Daniel
daniel123 is offline   Reply With Quote
Old 11-07-2011, 08:12 PM   #2
Yes, it is okay to just connect the two wires to positive/negative wires in the junction box. If the fixture doesn't have an earth ground connection, then it doesn't require an earth ground.
alan45371 is offline   Reply With Quote
The Following User Says Thank You to alan45371 For This Useful Post:
daniel123 (11-07-2011)
Old 11-07-2011, 08:21 PM   #3
Thanks for the feedback Alan.
Tags
electric outlets , grounding , light fixture , plug-in to hardwire , polarized
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 07:13 PM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 09:54 AM
Wiring of bare copper wire in a light fixture Fleet_Foxes Electrical 5 07-16-2009 09:44 PM
Ceiling fixture red wire????? meshell06 Electrical 4 10-19-2008 10:20 PM
Stobe light ground wire getting hot! kaliyg Electrical 3 08-21-2008 10:27 PM
