Grounding Issues/questions - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 03:53 PM   #1
Grounding issues/questions
Hi Guys,
I suspect that the water pipe to which my electrical panel is grounded may be carrying current.
How can I measure whether the water pipe is in fact carrying current?
Is it normal for a water pipe used as a ground to carry current, or does that only happen if there is an electrical problem?
Thanks in advance.
jsp056 is offline   Reply With Quote
Old 03-25-2010, 04:07 PM   #2
Master Electrician
Rewards Points: 3,678
It is not normal. What are your suspicions?
brric is online now   Reply With Quote
Old 03-25-2010, 04:13 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes, it can be tested but what would make you believe it is in fact carrying a current?
Old 03-25-2010, 04:35 PM   #4
brric & nap, thank you for your replies.
The reason I suspect a current is because I have measured an unusually high level of EMF on the pipe using a gaussmeter.
Old 03-25-2010, 04:40 PM   #5
nap
You talking to me?
nap's Avatar
the first thing I would do is turn off the main power to your house and re-check.
If you still have a reading, there is something other than your power causing the problem.
Old 03-25-2010, 04:43 PM   #6
Master Electrician
If you have access to clamp-on ammeter see if it gets a reading. Visually inspect the neutral connections for your service at the pole and at the house.
Old 03-25-2010, 04:54 PM   #7
If I turn off my electrical panel, the high reading is still there (although not as high as when the panel is on with lights & appliances in use), however with the panel still off if I then disconnect the ground from the pipe the reading drops.
At this point, I should explain that the same water pipe runs to 3 other townhomes, and all 4 units are grounded to the same pipe. However, there is only a high reading when my electrical panel is grounded to the pipe.
Old 03-25-2010, 05:00 PM   #8
Thanks - I'd probably need to get an electrician to look at that as it's beyond my level of knowledge.
Would you expect to see a reading with the clamp-on ammeter under normal circumstances?
Old 03-25-2010, 05:09 PM   #9
Master Electrician
No, not normally.
Old 03-25-2010, 07:25 PM   #10
nap
You talking to me?
nap's Avatar
I think it sounds like a neutral problem. Time to be cautious with electronic gear.
contact the power company and/or whoever deals with any common elements of the townhomes.
Old 03-25-2010, 08:26 PM   #11
So the cause for a neutral problem is likely to be external (power company responsibility) rather than caused within my own home (for which I'd need my own electrician)?
Old 03-25-2010, 09:37 PM   #12
nap
You talking to me?
nap's Avatar
based on the fact you still have, at least part of the problem current, even with your power turned off, I would suspect it is a problem common to all of those townhouses involved. That would either be the power company or whomever deals with the common elements of the townhouse group.
I would suspect it is part of the power company's system and is a poor neutral connection where it feeds to the houses. Since they ground their systems, and neutrals, it sounds like the water pipe is being utilized as a replacement or at least a parallel conductor for that neutral and it's poor connection.
Old 03-25-2010, 09:49 PM   #13
OK, thank you for your help nap, I'll look into that.
Old 03-25-2010, 10:50 PM   #14
Rewards Points: 1,418
If you disconnected the ground clamp from the water pipe and then tried to measure voltage between the ground wire and the pipe, you might detect a problem possibly with your neutrals.
If you disconnected the ground clamp from the water pipe, also measure voltage between neutral and both hot lines to see if there is a difference.
Should you find a significant voltage difference between the two legs of the 120/240 volt service (to neutral) and all circuits are affected, and reconnecting the ground clamp to the water pipe makes the difference less profound, then there is a good chance there is a neutral problem on the power company's lines.
Old 03-26-2010, 12:10 AM   #15
Thanks AllanJ - I'll discuss that with my electrician.
grounding electrode conductor question bsperr Electrical 8 12-05-2009 10:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 12:06 PM
Grounding light box n0c7 Electrical 10 10-06-2008 04:20 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
