Grounding Hot Tub - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 09:09 AM   #1
grounding hot tub
why do i need to ground anything metal to my tub I have a metal frame gazebo on my patio Do i need to ground this?
mholub77 is offline   Reply With Quote
Old 09-01-2010, 09:16 AM   #2
How close is it to the hot tub ?
There is a requirement for a bonding grid 3' around the hot tub
Old 09-01-2010, 09:32 AM   #3
hot tub
the gazebo is rite next to the hot tub
Old 09-01-2010, 07:44 PM   #4
Licensed Engineer
Rewards Points: 175
Then the gazebo needs to be connected to the bonding grid.
MI-Roger is offline   Reply With Quote
Old 09-01-2010, 08:03 PM   #5
" Euro " electrician
frenchelectrican's Avatar
You will have to bring the bonding conductor from the pump motour to the gazebo post.
You use the same conductor as green conductor to the pump motor or bare conductor { useally 6 or 10mm˛ ( #10 or #8 AWG } unless you have bare 16mm˛ { #6 AWG } from spa subpanel to the pump motour or frame location that one of few locations you bonded it.
The reason why to bond it due keep the voltage graduent to minuim.
Don't ever think about ground rods it is not bentifal in this useage.
Merci.
Marc
Old 09-01-2010, 09:25 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
No, you need to BOND it like the others have stated.
Bonding and grounding are two different things, especially with respect to pools and spas.
grounding electrode conductor question bsperr Electrical 8 12-05-2009 09:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Grounding light box n0c7 Electrical 10 10-06-2008 03:20 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
