Grounding A Hanging Chandelier Made For A Electrical Box Mount - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 05:42 PM   #1
Grounding a Hanging chandelier made for a electrical box Mount
I am hanging a new chandelier. There is no electrical box to mount it to. I plan to splice it to a plug and plug it into a wall outlet. The chandelier has a copper grounding wire. I have nowhere to ground it. Do I need to ground it if it is going to be plugged into the wall?
mjgumbo is offline   Reply With Quote
Old 03-21-2010, 06:06 PM   #2
Journeyman Wireman
Rewards Points: 150
How do you intend to splice on a plug? How will you hang the chandelier from the ceiling? How will you turn it off and on?
It's my opinion that modifying a light fixture by adding a cord cap (plug) will violate the UL listing.
Jupe Blue is offline   Reply With Quote
Old 03-21-2010, 06:13 PM   #3
The chandelier will be on a chain hanging from a toggle hook (swag style?). I plan to run the cord through the chain to an in-line on off switch and then plug into the wall.
Old 03-21-2010, 06:42 PM   #4
the Musigician
DangerMouse's Avatar
They sell them at the store that way.....(ungrounded, 2 wires with a 'roll/click' switch.)
If you have a grounded outlet and fixture, use 3 strand wire to braid through the chain.
Personally, I would use the grounded version if it's available to you to use.
If the outlet is two prong, (no ground hole) you can replace it with a GFCI outlet.
But... I might add too that Jupe Blue is absolutely correct in the UL approval.
If the house burns down, the insurance won't pay. Once you modify it in any way, unless you get it inspected and approved......(unlikely) well, you know.....
DM
Old 03-21-2010, 06:50 PM   #5
the Musigician
Can you shoot us a photo of the fixture? And the area you plan on putting it?
Perhaps we can recommend a safe and LEGAL way to mount it?
DM
Old 03-21-2010, 07:54 PM   #6
Most overhead fans I have seen have pull chains to turn the light on & off & the fan on & off
Or you could connect a wireless switch
I've never had to do this, but wouldn't have any problem with installing one like that in my house if I had to
They do sell fans w/cords, probably the same model, just a cord tossed in there
I would use a 3 wire cord/plug
This is done fairly often on older homes where getting a wire to the center of the ceiling is very difficult if not impossible
Seems like you are using lamp cord with an inline switch ?
Old 03-21-2010, 08:01 PM   #7
the Musigician
I think the keywords here are: Hanging chandelier made for a electrical box Mount.
This fixture would likely have to be retro-fitted somehow to support the weight of the fixture to the ceiling, and also to the fixture itself to hold it up (chain or otherwise)! Of course, there are accessory parts (even kits) that can be used to accomplish this safely. Pretty much depends on the fixture itself at this point.
DM
Hanging Chandelier directly to exposed wood beam tim92887 Electrical 11 02-05-2010 10:33 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
Bizarre Electrical Problems - Grounding? CaptHanky Electrical 45 06-27-2008 10:18 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
grounding electrical boxes handifoot Electrical 5 05-07-2006 12:40 PM
