Grounding A Gutter - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 08:45 PM   #1
Rewards Points: 152
grounding a gutter
I've got a 24" wire pull gutter 20" from a sub panel. The gutter will have feeders from my main passing through it to the sub. It has a #6 ground wire passing through. There are no connections or splices in the gutter. It is just a place to pull wire and turn a corner. Can I run a #12awg green wire 20" back from the sub panel's ground bar and screw to the gutter's wall? Or do I have to tap the #6 wire as it passes through and bond it to the gutter's wall? It is effectively grounded by the EMT pipe, but I'm pulling grounds to all my subs anyway. I don't like just using pipe as my ground system.
David
n175h is offline   Reply With Quote
Old 02-21-2012, 08:50 PM   #2
Julius793's Avatar
Originally Posted by n175h
I've got a 24" wire pull gutter 20" from a sub panel. The gutter will have feeders from my main passing through it to the sub. It has a #6 ground wire passing through. Can I run a #12awg green wire 20" back from the sub panel's ground bar and screw to the gutter's wall? Or do I have to tap the #6 wire as it passes through and bond it to the gutter's wall? It is effectively grounded by the EMT pipe, but I'm pulling grounds to all my subs anyway. I don't like just using pipe as my ground system.
David
Do as you wish it doesn't need an additional bonding means.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
jbfan (02-22-2012)
Old 02-21-2012, 09:24 PM   #3
Licensed electrician
Rewards Points: 1,622
You could use a lay-in lug bolted to the gutter on the #6.
jbfan (02-22-2012)
Old 02-22-2012, 10:45 AM   #4
Rewards Points: 160
If you make no splices in the gutter there is no need to do anything but pass through the gutter. No grounding jumper is required.
The Following User Says Thank You to J. V. For This Useful Post:
jbfan (02-22-2012)
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Yankee gutter resurfacing options miamicuse Roofing/Siding 24 01-06-2012 08:20 AM
Grounding sub-panel at pool house CraigMW Electrical 12 08-19-2011 10:08 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
