#1 |
Grounding (Go Figure)
I am sitting here at work reading the posts and just thought of something.
Does anyone have any information on whether the "sharkbite" type connectors used in some plumbing still provide a continuous connection for grounding purposes? I am just curious and I understand that The Code now requires grounding to be within 5 feet of the entrance of the pipe to prevent problems such as this but more so with PEX and CPVC plumbing in use today. Just food for thought. Thanks, Rick |
#2 | |
E2 Electrician
Grounding (Go Figure)Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
The consensus seems to be no bonding, even from the manufacturer....
http://www.inspectionnews.net/home_i...ap-jumper.html
#1 - If you don't know what you're doing - get a licensed electrician! #2 - If you follow my advice and something bad happens see # 1 Electricity bites hard, and it could be the last thing you feel... Good Luck! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Thanks for the replies.
I thought there would be some continuity but it is nice to hear it from the horses mouth. Thanks, Rick Lee |
| Display Modes | |
| cable line grounding | amakarevic | Electrical | 56 | 05-15-2012 10:22 PM |
| Fedder for 100A subpanel 100' from main | jheiderich | Electrical | 5 | 02-13-2012 08:10 PM |
| grounding of main panel and sub panel in older house | linkysys | Electrical | 2 | 10-01-2009 05:34 PM |
| Anyone want to take a shot at why #6 to attach antenna ground to breaker? | Piedmont | Electrical | 44 | 01-08-2008 05:11 PM |
| NEC Question | Jafsvcs | Electrical | 1 | 06-13-2007 06:45 PM |
