Grounding To A Gas Line - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 10:29 AM   #1
grounding to a gas line
the cable guy was out to fix my service. after he left i noticed he grounded the cable line to a gas line. is this ok???
Jacques is offline   Reply With Quote
Old 10-13-2008, 10:44 AM   #2
1610 CUB's Avatar
Rewards Points: 150
Its NOT o.k. get him back and have move it to a water pipe
1610 CUB is offline   Reply With Quote
Old 10-13-2008, 10:44 AM   #3
Rewards Points: 58
No, Have them come back out and do it right. Preferably to the ground rod or ground rod conductor.
Old 10-13-2008, 10:46 AM   #4
1610 CUB's Avatar
Rewards Points: 150
Make him drive a 8' ground rod
Old 10-13-2008, 11:21 AM   #5
Everything (electric, phone, cable TV, etc.) should be grounded to a single point of ground (the same spot).
Billy_Bob is offline   Reply With Quote
Old 10-13-2008, 11:39 AM   #6
Everything is supposed to be bonded together, is their any way you could pull a ground there?
rgsgww is offline   Reply With Quote
Old 10-13-2008, 04:05 PM   #7
Rewards Points: 58
This is correct. It should all go back to the main bonding at the service. The ground rod is the best way to be sure it is connected to the system. The potential needs to be the same for everything grounded in the dwelling and outside the dwelling.
Old 10-13-2008, 04:06 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
This is not accurate. A grounding system is not restricted to one point. Many things can be bonded to any point on the GES (grounding electrode system).
Also, just bonding/grounding to a water pipe is not always correct or safe. Only certain portions of certain water piping systems are safe/correct to connect a ground/bond to.
Old 10-13-2008, 05:17 PM   #9
Registered User
Termite's Avatar
The home's gas piping system is required to be bonded. This can be accomplished by a bonding conductor and a clamp, but is normally accomplished via metallic connection to the HVAC system, which has an equipment grounding conductor.
The gas piping system cannot be used as a grounding electrode however, like the water line often is.
I'm not too well-versed on cable TV wiring, but I imagine the installer is connecting to the gasline in an attempt to use it as a grounding electrode (in case of lightning, etc). Although it is bonded to the grounding system via the furnace, I don't think that it is a best-case means of doing this.
Old 10-13-2008, 05:44 PM   #10
On a Central Grounding Point,
Google 1200 pages...
http://www.google.com/search?num=20&...22&btnG=Search
Old 10-13-2008, 05:59 PM   #11
What's your point? Most of that is referencing electronic equipment.
There is NO "central grounding point" with regard to a building's AC wiring system.
Maybe you can point me to a more accurate description of what you are talking about, as opposed to 1200 Google hit pages.
Old 10-13-2008, 06:02 PM   #12
Electrician
Check out art 820.40(B)(1)
chris75 is offline   Reply With Quote
Old 10-13-2008, 11:17 PM   #13
Rewards Points: 2,350
And then what? What does this accomplish, exactly?
Old 10-14-2008, 04:49 PM   #14
Electrician
I generally get a good workout when doing this, so I think its healthy to drive ground rods.
Old 10-14-2008, 04:50 PM   #15
Registered User
Termite's Avatar
As I thought, he's going at this wrong by grounding coaxial's shield to the gasline and not the grounding electrode. Thanks for the code reference. That's definately one section I've never spent much time in.
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
moving incoming power line and grounding rod amakarevic Electrical 3 07-29-2008 12:24 AM
grounding cable tv and normal phone line? russrp Electrical 15 07-05-2008 04:03 PM
power line noise sciguy125 Electrical 5 12-02-2007 02:39 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
