Grounding An End Of The Run Outlet For A Smoke Detector - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 05:24 PM   #1
Grounding an End of the Run Outlet for a Smoke Detector
Hi,
I've got a series of hard wired smoke detectors in plastic remodel boxes. Their connected via 12/3 wire. The detectors have a pre-fab pig tail that has only red, black and white wires. How do I ground the last outlet?
WoodmanFL is offline   Reply With Quote
Old 12-16-2011, 05:28 PM   #2
Licensed electrician
Rewards Points: 1,758
Smoke alarms are not grounded. Just leave the grounding conductor in the back of the box.
Old 12-16-2011, 06:55 PM   #3
Thanks again Jim.
Old 12-16-2011, 10:31 PM   #4
Electromagician
How did you ground the other outlets?
I have a box of capacitors that can lower your power bill. just ask me how.
powerfactor is offline   Reply With Quote
Old 12-17-2011, 07:44 AM   #5
Tie the grounds together, but the end run only had one wire and no ground from the detector.
Old 12-17-2011, 02:01 PM   #6
Electromagician
Jim is correct, just do like he says and you'll be fine.
Smoke detector wiring? km2009 Electrical 4 08-15-2009 08:42 PM
Changing an outlet, Grounding Procedure jamiedolan Electrical 15 10-12-2008 10:07 AM
Hardwired Smoke detector wiring whisper Electrical 2 07-19-2008 05:46 AM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-18-2008 11:03 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
