Old 05-04-2006, 11:22 PM   #1
grounding electrical boxes
I have run a new 240 line for my electric range. 6 guage, three wire with a bare ground. I'm using the current up to date receptacle as this is a new range.
My question is this, I have used a metal electrical box, do I need to tie in the bare ground to the box itself? There is no green screw or clip to be found.
handifoot is offline   Reply With Quote
Old 05-05-2006, 03:13 AM   #2
If there are live wire splices in the box then you need to ground it, buy some ground srews at the HD(probably less than a buck), there should be a hole in your metal box that is threaded to receive the screw, just wrap the bare wire around it and splice it as needed.
Sparky Joe is offline   Reply With Quote
Old 05-05-2006, 04:41 PM   #3
A number 6 will not wrapp arround that screw. A short bit of number 10 solid wire is fine for the ground with a number 6 wire as the hot wire.
jwhite is offline   Reply With Quote
Old 05-05-2006, 05:45 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
I would assume the #6 copper cable he is running has a #10 ground. It does if it is NM cable.
Old 05-05-2006, 08:01 PM   #5
Its tough to be polite when you gotta state the obvious.
Old 05-07-2006, 12:40 PM   #6
I guess it should have been obvious, Ive been using blue plastic boxes up to now and needed some clarification on the metal thing. Yes, the ground wire is 10 guage and is now pigtailed to the box.
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Boxes recessed too deep rondo Electrical 10 12-01-2012 07:46 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 08:59 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
