Old 06-30-2008, 12:53 PM   #1
Question
grounding dryer outlet
the dryer outlet i got only has three inlets for the hot and neutral wires of 10-3 cable. no inlet/screw for grounding, like regular ones do. i just piggytailed the ground wire around one of the receptacle braces into which the outlet gets screwed in. not sure if that was the right thing to do. do they make dryer outlets with a grounding screw ?
thanks,
- a -
Old 06-30-2008, 01:16 PM   #2
Licensed Pro
If the dryer circuit is wired with 10/3, you must use a NEMA 14-30 receptacle/plug that accommodates both hots, neutral, and ground.
Old 06-30-2008, 01:31 PM   #3
is this always 4-pronged ? the cord i got for the dryer has a plug that is only 3-pronged and one prong is bent at a right angle ? i am not sure whether i will be able to just get an outlet that matches this plug but does meet the specification you gave or i will have to get both a different cord and outlet ?
on the other angle, which cable should be used with the outlet/cord combo that i did get ? the dryer works fine the way i set it up, BTW.
Old 06-30-2008, 01:43 PM   #4
joed's Avatar
You must change the dryer cord to a four prong type. If you have the manual for the dryer it should have the instructions on how to do that.
Old 07-05-2008, 10:05 AM   #5
Master Electrician
JohnJ0906's Avatar
This shows the bond strap on a range (dryer is pretty much the same) along with it removed, and a 4 wire cord installed.
http://s125.photobucket.com/albums/p...dryer%20cords/
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Running AC off of a Dryer Outlet TheCrow Electrical 7 06-16-2008 08:11 PM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-19-2008 12:03 AM
Dryer outlet adjacent to laundry/utility sink bjstewa Electrical 5 02-12-2008 09:10 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 05:14 PM
