Grounding For Detached All-metal Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2008, 04:48 PM   #1
Grounding for detached all-metal garage
Hi.
I've researched grounding requirements and NEC code extensively for detached garages. I am adding a 60-amp subpanel into an existing garage about 70' from the main service entrance panel, and won't go into extreme detail, but the subpanel will have its neutral isolated from ground, and the ground bus will be bonded to the subpanel, and a separate ground rod for the ground bus will be added for lightning protection.
The questions that I can't find answers for concern the fact that the garage is all METAL; steel I-beam construction with aluminum walls. So:
1. Should the metal garage be grounded by bonding it to the subpanel, either by direct installation to the interior walls of the structure, or through a bonding strap from the subpanel to the metal walls, thereby tying the whole structure to ground ?
OR
2. Should the metal garage be grounded by bonding it to the new grounding rod via a bonding strap, thereby tying the whole structure to ground?
OR
3. Should the metal garage be completely isolated electrically by using insulated backing boards to mount the subpanel in the metal garage, using non-metallic junction/switch boxes, using nothing but grounded plugs and wiring with a separate ground, etc).
I can't find any answers at all regarding the grounding of a detached metal garage.
geeswanie is offline   Reply With Quote
Old 07-02-2008, 05:09 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
1 or 2 and drill and tap a lug on your structural steel not the walls. Run a jumper from your ground bar to your lug. 250.32, 250.50, 250.52
wirenut1110 is offline   Reply With Quote
Old 07-02-2008, 05:22 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Structural steel and building steel are certainly in the NEC.
See the Articles quoted above plus 250.104.
Old 07-03-2008, 07:31 AM   #4
k, thanx. I'll check out the references.
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Grounding a non-grounded metal blower o2barockstar Electrical 1 10-22-2007 08:53 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
