Grounding Cooktop Correctly - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 01:30 PM   #1
Grounding cooktop correctly
I'm installing a new Bosch 36" Induction cooktop (I posted a rather convoluted post regarding this a few days ago). The cooktop has no 120v component so there are only two hots and a ground. Wondering how to ground this thing (and box) correctly. Can I race the ground around a screw in the j-box and connect the remaining wire to the ground on the cooktop? or should I terminate the ground from the romex in the box and then attach the ground from the appliance to the box? I afraid of creating some kind of ground-loop with such a high powered appliance (50A).
Booron is offline   Reply With Quote
Old 12-08-2009, 01:36 PM   #2
300zx's Avatar
Post
There should be a place to ground the cooktop.Did it come with a whip or is it hardwired there should be a green screw to ground to if hardwired can you post a pic of the connections ?
300zx is offline   Reply With Quote
Old 12-08-2009, 01:41 PM   #3
Yeah, the cooktop has has two-hots and a ground. wondering how to ground the cooktop and the j-box correctly with just the single ground wire from the 6-2WG.
Old 12-08-2009, 01:56 PM   #4
I'd almost think leaving the bare long, twisting it around the box grounding screw, then going top the cooktop would work
All #6's I've connected have landed on a breaker or connection point made for it
Old 12-08-2009, 01:56 PM   #5
300zx's Avatar
Post
Is this a metal j-box? if so leave the solid bare wire from the 6-2 w/gound longer than the others bond the ground wire to the metal box with the ground screw leave the extra ground so you can wire=nut it to the ground on the whip from stove.
Old 12-08-2009, 01:58 PM   #6
300zx's Avatar
Post
Dave beat me to it.
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
