Grounding Cold Water Pipe In Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 02:47 PM   #1
Rewards Points: 1,062
Question
grounding cold water pipe in shed
my shed has both water and a 50A sub panel. the wire was run 3ft under ground in a conduit. i was wondering whether i need to ground the cold water pipe inside the shed.
thanks
Only hot or cold water DiyPadawan Plumbing 8 10-20-2010 08:13 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 09:49 AM
