Grounding Circuits In Barn - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2008, 01:25 PM   #1
Grounding circuits in barn
I am going to run 2 20 amp circuits to my barn which is 75' from the load center at the house. One will be a 240V circuit for my sprinkler pump and the other will be a 120v for lighting and a couple outlets.
I am planning on running conduit from the load center to the barn and will use #12 THHN. My question is what to do about grounding the sprinkler pump. It is connected to a 14' driven well via steel pipe. Should I connect the pump to the ground wire I run from the load center or does the well casing act as a ground?
I don't want to end up bonding the load center to the well casing with a 75' #12 wire.
Also since this is a steel pole building should I bond the ground to the barn itself?
businmike is offline   Reply With Quote
Old 06-01-2008, 10:12 AM   #2
I don't think you can run a 110v and 220v circuit to a separate structure without putting a subpanel out there (I forget the exact rule - isn't it something like 2 110v circuits is ok but any more and you have to install a panel?). Might be cheaper anyways to run 4 conductors to a panel in the barn, rather than the 6 you'd have to run as you have it planned. Plus if you want to add more circuits in the barn later, you won't have to pull more wire.
NateHanson is offline   Reply With Quote
Old 06-01-2008, 10:22 AM   #3
joed's Avatar
Rewards Points: 12,018
Under code you can not run two circuits to a detached building. To do what you are planning requires a sub panel to be installed in the barn,
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 07:37 PM
Running Power to a horse barn Lusco Electrical 3 04-26-2008 04:34 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
