Grounding Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2007, 06:02 PM   #1
Eibwen
Grounding Cable
I'm getting ready to install my weather station on a brick chimney
[think old time tv antenna type install]
I would like to run the lightning grounding wire around the soffit about 20 feet to a point where I can install the ground rod without having to bore thru the new pool patio concrete. The cable may be exposed to sunlight and obviously will need to be sheathed since it will be in contact with the house.
Any suggestions on cable type for this application and conductor size solid/stranded?
Sammy is offline   Reply With Quote
Old 04-16-2007, 06:20 PM   #2
joed's Avatar
Rewards Points: 12,926
If the weather station has power going to it, the ground should be connected to the grounding system already in place on your house.
Old 04-16-2007, 06:20 PM   #3
does this thing do any communications or does it just look like something that does?
The only code I can find is for radio and tv receiving equipment.
Number 10 run at streight as possible to the ground rod, and number 6 from that ground rod to the rest of the ground rods for the electrical service.
Master Electrician
jwhite is offline   Reply With Quote
Old 04-16-2007, 07:00 PM   #4
Eibwen
It will have low voltage power to it. My concern is from a direct lightning strike to the metal pole it will be mounted on.
Old 04-16-2007, 08:32 PM   #5
Rewards Points: 6,652
You will have to mount a ground rod in dirt, not through Cement. That means, either cutting a fair size square chunk out, or runing the cable a distance. This also means, not running the ground wire back into the house, which is a big no-no.
Old 04-16-2007, 09:03 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Greg, while the letter of the code does say the entire 8' length of the rod shall be in contact with the "soil" I don't think anyone would complain about drilling a 5/8" hole in concrete and driving the rod through.
If an inspector told me to chop out a swath of concrete to sink an almost useless ground rod I'd find another inspector.
Old 04-16-2007, 09:10 PM   #7
The whole reasoning, is because Cement can contain conductive materials such as ores and rebar, which can contact the Grounding rod, rendering it useless. That is why a section about 1-2' should be cut as a square or such to allow for no contact with the materials in a slab.
Old 04-16-2007, 10:02 PM   #8
WHAT???
That is an interesting story. "Rendering it useless"?
I wonder if you have any documentation supporting this? I mean you didn't just make it up, right?
Have you ever heard of a Ufer? Also known as a "concrete encased electrode".
2' square huh? All I can say is wow!
Old 04-16-2007, 10:43 PM   #9
Yes, but the use of the Ufer grounding system is debatable, due to in order for it to work effectively, the grounding system has to be done by specs, and most concrete pours for the typical home will not conform to the criteria.
In all reality, this thread can lead into debates as to what is by code, and what is in Theory.
Old 04-17-2007, 04:28 AM   #10
How can conductive materail render a ground rod useless? Isnt the idea to drive it into conductive material? And if a concrete encased electrode is allowed why not one that is in 4 inches of concrete and the rest dirt?
Master Electrician
Old 04-17-2007, 06:18 AM   #11
Debatable? Then WHY did they make it mandatory in the latest edition of the NEC???
If there is rebar it MUST be used as a grounding electrode.
Can you elaborate as to "most concrete pours for the typical home will not conform to the criteria"? I am very curious about this.
Old 04-17-2007, 07:29 AM   #12
Unless the pour calls for it, a typical home slab will not have any rebar in it, and it will not meet the specs for a commercial structure. Also, most home builders will find short cuts to make sure costs are lower, and return is higher.
Old 04-17-2007, 07:41 AM   #13
Of course the slab won't but what about footings? Even a monolithic slab will have rebar in the footing portion.
This is not nearly always the case. At least not with the guys I work with. If you do tract and spec homes all day maybe.
BTW Greg, what is your trade?
Old 04-17-2007, 05:51 PM   #14
Eibwen
Uh Hmmmmmmm..
This tangent is starting to look like a side bar at the O. J. trial...
There is no rebar in the concrete. Fiberglass pool twenty feet away that is bonded.
I dont PLAN on going thru the concrete which is the reason for running the cable thru the soffit to a point it can be dropped down to bare ground.
My original question was as to a suggested conductor type, gauge, and sheathing.
Old 04-17-2007, 06:30 PM   #15
As far as grounding your dish to an electrode I would follow whatever the MFG suggests. I'm sure there is info in the manual about this.
Some I have seen suggest a #10cu, and this is the NEC minimum. I'm not sure how effective this would be as far as a lightning strike is concerned though.
If you do sink another electrode it MUST be bonded to the house's GES (grounding electrode system) with at least a #6cu wire.
See NEC 810.21 regarding grounding antennas.
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 08:01 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 10:04 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 07:21 PM
