Grounding Bushings For EMT - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 09:14 PM   #1
Grounding bushings for EMT
Can anyone tell me if a grounding bushing is required on both ends of EMT conduit between a meter base and the panel? It seems to me that only one should be needed but I've read on here that one is needed on both ends?? Doesn't make sense to me. Can anyone clarify? (My install is in the great white north here)
rovers1973 is offline   Reply With Quote
Old 02-24-2010, 10:04 PM   #2
I don't know the answer but your logic seems sound. Thing is, that's probably covered by local code so you'd probably do well to check with your city inspector(s).
brich is offline   Reply With Quote
Old 02-24-2010, 10:24 PM   #3
Electrician
Rewards Points: 778
Just the one inside the panel is all you need
darren is offline   Reply With Quote
Old 02-24-2010, 10:27 PM   #4
Thanks Darren, thats what I thought. The meter base is bonded with the neutral connection right?
On the topic of grounding, I need to ground my gas line with this new panel install. Can I run the ground from the gas line to the water line connection, and then run one wire from there to the panel, or do they have to be seperate runs? My water line is halfway from the panel to the gas line.
Old 02-24-2010, 11:34 PM   #5
Journeyman Wireman
Rewards Points: 150
Yes, you can run 1 continuous wire to bond both the gas and water piping.
Jupe Blue is offline   Reply With Quote
Old 02-25-2010, 12:19 AM   #6
Is it ok to splice together at the water line? There is an existing wire from the water pipe, but I have to add one from the gas line to pass inspection.
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 12:06 PM
Grounding light box n0c7 Electrical 10 10-06-2008 04:20 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
