Grounding A Building - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 09:09 PM   #1
Cool
grounding A building
I bought a metal garage and i was planning on runnig power to it from my pedestal and i figure out what wires go where , but my question is , do i need to attach a ground wire to it ( building ) or burie a cooper rod and attach it to it ??? or just the one coming from the pedestal to the sub panel ??? dos it make sense
thx for any help
hugom is offline   Reply With Quote
Old 03-03-2010, 09:14 PM   #2
Where are you located ?
For a detached building you run 2 ground rods
The Following User Says Thank You to Scuba_Dave For This Useful Post:
hugom (03-03-2010)
Old 03-03-2010, 09:21 PM   #3
Thumbs up
...And all the metal studs and beams must be bonded to the building (Garage/structure) Ground.!
spark plug is offline   Reply With Quote
The Following User Says Thank You to spark plug For This Useful Post:
hugom (03-03-2010)
Old 03-03-2010, 09:48 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
you either need a second redundent (spell check) ground rod in series with first rod or a water service in the building to ground to
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
hugom (03-03-2010)
Old 03-03-2010, 09:55 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and if you have a concrete foundation with enough rebar in it to qualify as a concrete encased electrode, you MUST bond to that as well.
The Following User Says Thank You to nap For This Useful Post:
hugom (03-03-2010)
Old 03-03-2010, 10:06 PM   #6
Yeah there is a bar sticking out in one of the corners, so do i attach that bar to the building ???? Then from the sub panel to be metal studs ??
Thx for helping
Old 03-03-2010, 10:32 PM   #7
nap
You talking to me?
nap's Avatar
is the building steel framed or wood framed?
Old 03-04-2010, 10:44 AM   #8
Rewards Points: 204
Sounds like you need a qualified electrician for this job. Just by the questions you are asking I know you are not up for this job by yourself.
Do yourself a favor and hire someone.
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
