Old 03-30-2011, 05:34 PM   #1
Grounding/bonding of new above ground pool
The pool installers are setting up an above ground pool Friday. We are good as far as the pump power and conv. outlet. What is required of the electrician for grounding/bonding of the actual pool shell, ladder, etc. ?
ms1976 is offline   Reply With Quote
Old 03-30-2011, 06:15 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
The pool company should know what is code in your area. If not, contact the city hall to verify if Permit was pulled for the job, and also same for the electrical & plumbing. This all should have been thought about before shovel hit ground.
Old 03-30-2011, 06:27 PM   #3
Licensed electrician
There should be an bond grid or wire run around the walk surface under the ground, the water should have a bond fitting installed and all metallic surfaces like the ladder and pool shell should all be bonded together with a min of a #8 copper conductor
Above ground pool cover question joeg679 General Discussion 8 08-03-2010 05:41 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
Grounding an above ground pool wcolon Electrical 18 09-02-2009 03:25 PM
Above Ground Pool Privacy Fence hammermonkey Building & Construction 4 02-25-2009 05:27 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 02:50 PM
