Grounding Amp In Car - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2013, 05:06 PM   #1
Grounding amp in car
I'm grounding my amp to the frame of my truck. I was wondering if its ok to have my ground screw/terminal directly under the carpet. Not the regular carpet, the thicker underlining carpet between the actual carpet and frame. Maybe throw a couple layers of electrical tape on top?
Bubski27 is offline   Reply With Quote
Old 08-05-2013, 05:23 PM   #2
Rewards Points: 744
Under the carpet, that's called a carpet pad....
It's fine. I wouldn't even worry about the electrical tape.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
mpoulton (08-05-2013)
Old 08-05-2013, 05:42 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,938
Not a problem. It's usually easiest to ground to one of the seat or seatbelt bolts, though.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
2-2-4 SEU - Smaller Neutral? BRT Electrical 18 09-23-2012 09:25 PM
Replacing Light Fixture with No Ground Wire in Home panorama Electrical 42 09-14-2012 09:35 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Grounding sub-panel at pool house CraigMW Electrical 12 08-19-2011 10:08 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
