Grounding A 3-way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 06:05 PM   #1
Rewards Points: 101
Grounding a 3-way switch
Do 3-way switches need to be grounded? I've noticed some 3-way switches do not have a grounding terminal, and the 3-ways in my home are not grounded even though they have terminals. This is also in plastic boxes. I have some three way switches to install in my basement and they do not have grounding terminals.
wvphysics is offline   Reply With Quote
Old 01-18-2010, 06:35 PM   #2
joed's Avatar
Rewards Points: 12,362
If they have ground screws they should be grounded.
Old 01-18-2010, 07:06 PM   #3
Licensed electrician
Rewards Points: 1,474
Switches should be grounded. It sounds like you bought old stock.
The Code Article is 404.9(B)
Old 01-19-2010, 12:01 PM   #4
Rewards Points: 518
Depends where you are. In Canada, light switches do not need to be grounded, however, the metal box they reside in does need to be grounded.
n0c7 is offline   Reply With Quote
Old 01-19-2010, 12:23 PM   #5
Rewards Points: 101
I'm in WV,which is under NEC 2005 at the moment and my house was built in 2004, so then was maybe NEC 1999? I did read somewhere around section 404.2 (in the 2005) that in 3 and 4 way switches "switch loops shall not require a grounded conductor." could this be related? Which part of three way wiring is the "switch loop"?
Old 01-19-2010, 12:32 PM   #6
A switch loop is when the white wire is used as the feed to a switch. It is no longer a neutral. Since 1999 NEC is it required to be reidentified as a hot conductor.
Old 01-19-2010, 01:45 PM   #7
Rewards Points: 101
If I attached this picture correctly, below is my setup. The white and black wires going to the light are in one cable, and the other white black and red cables are in another. Does the above section regarding switch loops not needing grounded apply to either of these switches?
Old 01-19-2010, 03:32 PM   #8
The ungrounded conductor they talk about is a neutral.
The grounding conductor is the bare or green. It is needed on switches regardless of single pole, three way or switch loop.
Old 01-19-2010, 08:19 PM   #9
Inspector/Instructor
codeone's Avatar
Heres a block diagram showing your equipment grounding conductor
codeone is offline   Reply With Quote
grounding switch? Jeremy Hillary Boob, PhD Electrical 15 08-02-2012 04:51 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
