Grounding 2 Circuits In One Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 07:54 PM   #1
grounding 2 circuits in one box
I've got a couple two gang boxes with each receptacle in a separate circuit.
I'll call them circuit 1 and circuit 2.
My read on NEC Article 250.148 is that all the bare equipment grounds should be together.
I've got grounds from line in and line out and receptacle 1 in a red wire nut, a the same with circuit 2.
I've run a length of bare line between the two wire nuts, so each nut has 4 wires and the grounds from both circuits are connected by the jumper.
Is this an approved way of connecting the grounds, or should I put 6 wires in a big ol' blue wire nut?
Any advice is appreciated.
Bill
itin1200 is offline   Reply With Quote
Old 10-27-2010, 08:00 PM   #2
Rewards Points: 330
tie together .
oleguy74 is offline   Reply With Quote
Old 10-27-2010, 08:06 PM   #3
Electrical Contractor
kbsparky's Avatar
Either way is acceptable.
-KB
Old 10-28-2010, 01:27 AM   #4
" Euro " electrician
frenchelectrican's Avatar
You can go either way as long you have room in the junciton box.
Merci.
Marc
Old 10-28-2010, 09:10 PM   #5
Thanks for the affirmation guys.
All worked out well.
Grounding from Junction Box too Main tlj Electrical 5 10-25-2009 12:48 AM
Grounding for different circuits in the same box? epeterson777 Electrical 23 03-19-2009 08:04 PM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Grounding circuits in barn businmike Electrical 2 06-01-2008 09:22 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
