Grounding A 2 To 3 Prong Adapter - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 04:45 PM   #1
Grounding a 2 to 3 prong adapter
Hello all! New here and totally new to DIY stuff in general. I have a quick question. I am sure my vocabulary is all wrong. Forgive me.
I have an adapter that turns a two prong outlet into a three prong (grounded?) outlet so that I can plug in a work bench light. There is a small metal green ring sticking up from the adapter and it says to, "connect tab to grounded screw." I have no idea what to do here. The fixture is up on the ceiling in my garage; I don't have a grounding screw, and if I get one I don't know where to ground it to. Basically, I am just lost.
That said, of course, everything works fine without attaching the tab to a screw. But I figure the label is there for a reason. What should I do?
Let me know if I can clarify anything.
frudoc is offline   Reply With Quote
Old 04-21-2011, 04:55 PM   #2
Too Short? Cut it Again!
If it is a light fixture, I would not sweat it unless you are spraying water at it and standing in your bare feet or something.
Old 04-21-2011, 05:22 PM   #3
OK. Thanks. I figured as much. No one will be able to get near it, and it will remain nice and dry.
Thanks again!
Old 04-21-2011, 05:27 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
That U shaped tab goes under the screw that holds the cover on the receptacle. It only works if the receptacle is grounded.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
DangerMouse (04-21-2011)
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 09:59 PM
How to Ground 3-to-2 prong grounding adapters Lantisu10 Electrical 7 10-26-2009 04:57 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
