Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 06:04 PM   #1
grounding
What are the requirements for grounding when connection 1 inch emt conduit to a breaker box?
bob804jac is offline   Reply With Quote
Old 01-21-2012, 06:13 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
It has a mechanical ground through the conduit,where is this being installed?
Certain locations require a seperate ground wire and bonding depending on use
plummen is offline   Reply With Quote
Old 01-21-2012, 06:16 PM   #3
MarginallyQualified
Rewards Points: 2,464
Metal conduit to metal box = grounded.
IF you are pulling a ground conductor through the pipe as well...
that's belt & suspenders.
The Following User Says Thank You to TarheelTerp For This Useful Post:
bob804jac (01-21-2012)
Old 01-21-2012, 06:20 PM   #4
conduit will come directly into breaker box and will be connected to the box with compression type clamps. Does the metal rings used to tighten the conduit to the box provide a legal ground or do I need some other type of ground clamp?
Old 01-21-2012, 06:25 PM   #5
plummen's Avatar
Yes thats considered a mechanical ground.
Old 01-21-2012, 06:41 PM   #6
Rewards Points: 506
Bond or ground?
jlmran is offline   Reply With Quote
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Grounding sub-panel at pool house CraigMW Electrical 12 08-19-2011 10:08 AM
Grounding rods for tv antennas Wasatch Rebel Electrical 4 06-02-2011 07:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
