Grounding 100 Amp Service - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2009, 11:02 AM   #1
Grounding 100 Amp service
Hello, I have a question about grounding my 100 amp box. when I bought the house thee is a ground wire that is ran to the water line but the water line is copper not metal. Is this proper and if not where would I run the ground wire to and what gauge wire is needed? Thanks!
soggycashew is offline   Reply With Quote
Old 09-11-2009, 11:29 AM   #2
Rewards Points: 130
Since when is copper not metal? Copper is an excellent conductor of electricity. Thats why they make WIRE from copper.
Your question; Yes, its right. There should also be another #6 conductor (wire) going to a grounding electrode (ground rod) or other approved grounding means.
If it worked before you worked on it. You did something wrong.
Old 09-11-2009, 11:39 AM   #3
thanks
Grounding a 400 amp service with two 200s rgsgww Electrical 20 04-20-2009 08:05 PM
proper material for service grounding rod? Jim S. Electrical 9 02-05-2009 09:25 PM
grounding multiple service panels dbusz Electrical 11 10-18-2008 12:32 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Grounding new service TonyD Electrical 11 08-21-2006 11:03 AM
