Grounded Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2010, 05:10 PM   #1
grounded outlets
How do I replace old 2-prong outlets with grounded 3-prong outlets?
Danna is offline   Reply With Quote
Old 10-11-2010, 05:24 PM   #2
Rewards Points: 324
even though you have non-grounding outlet's,is there a ground wire in the romex?I run into this all the time with 60's houses.check for ground wires first.if no ground wire you must use a gfci outlet and must be labled NO EQUIPMENT GROUND.
oleguy74 is offline   Reply With Quote
Old 10-12-2010, 05:02 AM   #3
Rewards Points: 1,192
If it is fed by old Bx,measure volts to ground and if there is a ground, you can use a 3 wire receptacle.
bobelectric is offline   Reply With Quote
Old 10-12-2010, 07:10 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
This is not nearly always true, especially with old BX/AC cable.
The sheathing of older cable, without the thin aluminum bonding strip, CANNOT and should not be used as an equipment grounding means.
Simply having an electrical grounding path is not enough. A visual check is the ONLY way to tell.
I can go into more detail and provide code sections if needed.
Old 10-12-2010, 07:11 AM   #5
If you have no experience with electrical work, even something which seems as simple as this should be handled by an electrician.
In a case like this it is usually NOT as simple as it seems.
Old 10-12-2010, 12:42 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
old BX? actually there was never any BX that allowed you to use the sheath as an EGC. That is one of the improvements that was made when they got rid of BX (although even then BX was actually listed as AC cable).
Using the sheath on (actual) BX is not only illegal it is unsafe.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Advice needed for adding grounded outlets in old home Cool user name Electrical 13 08-30-2010 08:10 PM
non grounded outlets in the basement? TableTiger1 Electrical 19 02-08-2009 05:40 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Outlets are not grounded...what to do about it? OldHouse963 General DIY Discussions 10 04-14-2008 09:36 AM
