Grounded/bonded - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-18-2012, 07:16 PM   #16
Rewards Points: 528
Can i use this style on bonding?grounded/bonded-imag0146.jpg
hidden1 is offline   Reply With Quote
Old 11-18-2012, 07:21 PM   #17
Licensed electrician
Rewards Points: 1,634
I think the bond screw is just to the right of the large neutral lug.
Old 11-18-2012, 07:24 PM   #18
Rewards Points: 528
-so some of them did NOT use the green ones with the old 40+ year boxes
Old 11-18-2012, 07:42 PM   #19
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Probably not but but the vast majority are green but it is not always real apparent. If you look back at my previous post I circled the bonding screw hole.
Old 11-18-2012, 07:48 PM   #20
UAW SKILLED TRADES
Stubbie's Avatar
Can i use this style on bonding?Attachment 60732
Yes but if you by that factory it may not be bent correctly for the right height. Just buy a grounding lug/terminal like this and use some #4 bare copper or #4 green insulated stranded copper. Use a machine screw not a sheet metal screw to mount to the panel back. The best thing is to just go to a electrical supply and get the correct bonding screw and install it
Old 11-19-2012, 05:11 PM   #21
Rewards Points: 528
Thanks ,im going to use that style for grounding-going to neutral bar- you showed.Will there be any issues when inspected? Looked like pipe-metal- is grounding to the outside box but i still want to bond it via inside.
Here is a picgrounded/bonded-imag0149.jpg
