Ground Wires On Neutral Bus - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 10:52 PM   #1
Ground wires on neutral bus
Hi Guys Quick question
Is it ok to have equipment ground wires connected to neutral bus? There was no equipment ground bar. Neutral, ground and panel were bonded. It was the main panel
jprince is offline   Reply With Quote
Old 05-24-2009, 10:56 PM   #2
dSilanskas's Avatar
Yes its fine the only time you can't have neutrals and grounds on the same bar is if it was a sub panel
dSilanskas is offline   Reply With Quote
Old 05-25-2009, 12:09 AM   #3
Old 05-25-2009, 02:11 AM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
but take note. Each wire must be in it's own terminal. You cannot double up the neutrals.
Old 05-25-2009, 02:15 AM   #5
Can you double up on the grounds? The reason I ask is that I am missing several set screws, and I can't seem to find replacements anywhere, so I have grounds sharing spots.
Any idea where to find 5/16" fine thread set screws?
Miranda7 is offline   Reply With Quote
Old 05-25-2009, 03:06 AM   #6
Rewards Points: 2,350
Yes you can generally double up grounds of the same size. Go buy another ground bar and use the screws from it.
Old 05-25-2009, 09:49 AM   #7
nap
You talking to me?
nap's Avatar
the only caveat to doubling on the grounds and generally not a concern but to double upon grounds, the terminals have to be rated for more than one wire.
that info should be on the panel door or wherever the general info is posted within the panel.
most panels seem to have terminals rated for more than one wire for the ground bar.
Do ground wires require "green" wire nuts? epeterson777 Electrical 4 03-14-2009 12:49 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 04:15 PM
Neutral wires flakey Hemingway Electrical 7 02-19-2009 10:19 PM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 09:25 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
