Ground Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 11:20 PM   #1
Rewards Points: 180
ground wires
Had a quick question, just to double check ,in the main panel at ground bar can you have 2 ground wires the same hole and do they have to be same size ?
I know the neutral wires are to remain by themselves in neutral bar .
Thanks for any info
hidden 1 is offline   Reply With Quote
Old 06-27-2013, 11:40 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Thanks for any info
Most case useally not a issue and try to keep them in the same size due it easier to toqure the screw properly without damage the conductor.
Look at the bussbar listing to see what the max number of ground conductors it can fit in the opening ( most case useally two but some are listed for three so check it out )
Merci,
Marc
Old 06-28-2013, 07:03 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Most newer panels can accept two or even three grounds of the same size.
Old 06-28-2013, 04:00 PM   #4
Rewards Points: 180
Thanks.
I will move the #12 to the other #12 and away from the #10..for a more even bite .
Maximum wires in box for ceiling fan connection fan13 Electrical 10 07-29-2012 10:11 AM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
cimping ground wires together? drgkjd Electrical 5 05-29-2010 02:53 AM
