Ground Wire Size For 200A Subpanel? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 08:50 PM   #1
Question
Ground wire size for 200A subpanel?
I am in the process of building a house at a rural site which already has 200A service to a new outdoor feed-thru panel. Currently there are only two 20A circuits powering two GFCI outlets for construction use. I plan on installing a 200A panel as a subpanel in the house (as the existing outdoor panel is the main panel). Several people have suggested I use a direct bury 4/0-4/0-4/0-2/0 aluminum bundle, but after doing lots of online research it seems like I should do it the right way and run THWN or similar in conduit. Especially since there are trees nearby. It's easy enough to find wire gauge requirements and voltage drop tables, but I can't seem to find a definitive word on what size ground wire would be needed. The house will already have a "ufer" ground from the footings brought up via 4awg copper, but since the house panel will be a subpanel, I know it has to be bonded to the existing main panel. So my question is, what size ground do I need between the existing main and the house's subpanel?
jaserlet is offline   Reply With Quote
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
running wire for 50A subpanel in a detached shed amakarevic Electrical 10 03-17-2011 05:04 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
