Ground Wire Size For 200A Service? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 01:30 PM   #1
ground wire size for 200A service?
New construction. Got a 200 Amp panel - using copper conductors. The neutral and hot wires are 3/0 I believe. What size is the copper ground wire in the panel supposed to be?
Thanks.
lowcountry is offline   Reply With Quote
Old 06-23-2011, 01:52 PM   #2
Master Electrician
Rewards Points: 3,678
From the panel to the metallic water pipe entering the house and/or to the Ufer #4 copper or #2 Al. The NEC only requires #6 copper to the grounding rods however local codes may require #4.
brric is online now   Reply With Quote
Old 06-23-2011, 01:53 PM   #3
Mucho thanks!
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
rewire and new service entrance wire dghowery Electrical 4 10-13-2010 09:31 AM
EMT and WIRE size - 100 amp sub panel balansaj Electrical 6 05-18-2010 04:17 PM
Advice on current NEC codes to clear up wire size and service issue DIYALLTHETIME Electrical 2 03-05-2009 07:24 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
