Ground Wire In Rigid Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 10:48 PM   #1
ground wire in rigid conduit
I live in an area that requires all interior wiring to be in metal conduit. If you use flexible conduit, you must have a copper ground wire connecting the metal boxes are each end of the run.
I have some flex that was used when circuits were added as part of previous modifications. I want to add utility outlets in the crawl space and use the flex conduit to run the new wire from the panel. Once I get to the crawl space it will be in rigid conduit.
Should I extend the green ground wire through the rigid conduit or can I depend on the conduit for ground?
measure thrice is offline   Reply With Quote
Old 02-02-2009, 11:39 PM   #2
You should run the ground wire. It's not a lot of work or money and it makes a better/safer system.
Do you have to? Not everywhere, but here in AZ, you do.
220/221 is offline   Reply With Quote
Old 02-02-2009, 11:59 PM   #3
not much work at all
Thank you,
Pulling one more wire with the hot and neutral means counting to three instead of two.
The utility outlets will be GFCI because they will be in the crawl space. Do you think I should put an cover on them like you would use outside? I was concerned about them being exposed to dust since they will not be used too often. But when you do use them they need to be reliable.
Old 02-03-2009, 06:25 AM   #4
Remodeling Contractor
A snap cover plate would not be a bad idea there, but not required
Tags
conduit , ground
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 02:07 PM
Stobe light ground wire getting hot! kaliyg Electrical 3 08-21-2008 10:27 PM
ground wire in mc circuit woodturner Electrical 10 08-07-2008 12:34 PM
Running a ground wire T Blanco Electrical 3 01-07-2008 04:17 PM
pulling wire through old flexible conduit cbray Electrical 1 05-20-2005 04:55 PM
