Ground Wire Pigtail Size For 8-gauge Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 10:04 PM   #1
Ground wire pigtail size for 8-gauge wire?
I've created a 240-volt circuit in my basement garage with 8-gauge wire and a 40 amp breaker, running to a metal J box.
I need to ground the metal box with a pigtail, but stranded 8 gauge is too thick and doesn't work with the green grounding screw. Can I use 12 gauge wire for this purpose? or maybe stranded 10 gauge? Thanks.
bottlerockett is offline   Reply With Quote
Old 05-17-2012, 10:45 PM   #2
" Euro " electrician
frenchelectrican's Avatar
# 10 awg will work for this size. either bare or green conductor.
Merci,
Marc
Old 05-17-2012, 11:23 PM   #3
I tried 10 gauge to ground the box, and it's frustrating because the wire is braided. So when I tighten the green screw, the braids of wire push away from the screw, and I don't feel like I'm making a secure connection.
Can you buy solid 10 gauge, or would 12 gauge solid work? I don't get it.
Old 05-18-2012, 06:28 AM   #4
Sparky
Rewards Points: 510
you can buy solid #10, or a 'Sta-Kon' or similar fork/crimp terminal for your stranded wire.
Techy is offline   Reply With Quote
Old 05-18-2012, 06:37 AM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
They also make ring terminals that fit about every wire size out there but a #8 ground pigtail may be hard to deal with.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-18-2012, 06:56 AM   #6
Code05's Avatar
Rewards Points: 1,104
I am trying to figure out how he ended up with a #8 EGC to start with.
Code05 is offline   Reply With Quote
Old 05-18-2012, 11:28 AM   #7
Thanks all, I totally forgot about a crimping option.
Code05, can you explain what you mean? Not sure I understand your comment.
8 gauge wire and a 40 amp breaker are the appropriate size for my needs -- a dedicated circuit for a small welder or a future electric car charging unit in my garage.
Old 05-18-2012, 12:10 PM   #8
Code05's Avatar
You may have needed #8 for hots and a neutral, if needed, but the ground wire for a 40 amp circuit need only be a #10.
There certain conditions that require a larger ground, but this isn't one.
Is this circuit in conduit and you pulled a #8 ground?
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Ground Wire Size? ddawg16 Electrical 5 03-17-2012 02:04 PM
What size wire for above ground swimming pool pump jshep105 Electrical 12 05-28-2011 06:43 AM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 05:28 PM
Panel ground and wire size tns1 Electrical 25 09-18-2009 02:53 PM
