Hi all,
A little confused and wondering if anyone will be able to shed some light on this.
-Have a 100 amp service panel.
-Ground wire from the water line is connected to the neutral bus.
As you know, all line grounds for the house wiring are connectd to the ground connectors (on the metal body of the panel)
The question is this....If the main ground wire is on the neutral bus, and the neutral bus bar in
not connected to the metal body of the panel (I assume...), how are all the house wires grounded...?
thanks,
confused...
