Ground Wire On Old Maytag Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 11:55 AM   #1
Ground wire on old Maytag dryer
I have a Maytag dryer that is approximately 20 years old. Trying to convert it to a 4 prong cord. The problem is the green ground screw is about 6 incches from the back panel so the ground wire does not reach the ground screrw. How can I attach the groung wire?
denbo13 is offline   Reply With Quote
Old 11-02-2012, 11:16 PM   #2
Registered User
Rewards Points: 5,216
Welcome to the forums! I moved you to "Electrical" for better responses.
Gary
Old 11-03-2012, 12:03 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Can you provide a picture?
Old 11-03-2012, 12:05 AM   #4
For me and possibly others it is a bit unclear what you are asking. What do you mean by panel? Are you refering to the receptacle for the Dryer? Or the cord that connects to the dryer? Or maby the electrical panel where the feed for the dryer is? Maby go a tad more into detail
Marc05 is offline   Reply With Quote
Old 11-03-2012, 01:15 AM   #5
" Euro " electrician
frenchelectrican's Avatar
If my memory serve me right that the green wire you have there you will have to float it and run the cord green conductor driectally to the grounding screw. ( you will have to tape up the green wire on dryer side )
One way you can tell if this is correct is by using the DVM and run it in ohm scale and ring the green wire on the dryer itself and the neutral termail block ( it will useally be white and it will be in centre stud ) and if that ring or ping it soildly then you will have to do this as I posted above.
The reason why due the manufacter did ran the green wire from the netural point to the frame to bond it together so check it out as I posted above.
Merci,
Marc
Old 11-03-2012, 08:18 AM   #6
Rewards Points: 1,442
Get a short length of wire (a pigtail) and use it as an extension to reach the screw. Bare wire can be used for ground.
Sometimes you can trim back more of the jacket of a replacement appliance cord so the exposed wire ends are long enough to reach the terminals inside the dryer.
Inside the dryer, if you see neutral wires (should be white) attached to the frame directly or using a pigtail or a metal tab, remove that attachment and connect those neutral wires only to each other and to the white wire of the appliance cord. Note that not all white wires inside an appliance are neutral; do not undo or change any connections unless you are sure of what you are doing.
(Twisting wires together to make a connection is not good enough; use a wire nut.)
AllanJ is online now   Reply With Quote
Old 11-04-2012, 05:27 AM   #7
Electrical Contractor
kbsparky's Avatar
A common problem with many appliances. The green lead is simply not long enough to reach the green grounding screw.
I usually will strip some extra outer sheath off the cord, making the leads long enough to reach the grounding screw. The other leads can be curly-q'd up if they appear to be too long to reach their terminals.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
frenchelectrican (11-04-2012)
Old 11-04-2012, 10:13 PM   #8
That is one of my most common methold I have done either Americanie side or French side.
Merci.
Marc
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
How does grounding work? scyarch Electrical 44 06-12-2012 05:59 PM
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 02:07 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
