Is The Ground Wire Necessary? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 06:34 PM   #1
Is the Ground Wire Necessary?
I reviewed all the posts regarding ground wires, but did not find my particular issue. I want to change a hard-wired chandelier into a plug-in hanging lamp. It has a ground wire, but I don't want to use a 3-pronged plug. Is it okay to cut the ground wire off where it comes out of the top of the chandelier? Thanks!
seniorlady is offline   Reply With Quote
Old 11-19-2011, 06:50 PM   #2
Sfeyelectric's Avatar
Very bad idea, and i highly recommend against doing this.
Sfeyelectric is offline   Reply With Quote
The Following 3 Users Say Thank You to Sfeyelectric For This Useful Post:
ben's plumbing (11-19-2011), Code05 (11-19-2011), NJMarine (11-19-2011)
Old 11-19-2011, 07:08 PM   #3
Code05's Avatar
Rewards Points: 1,104
Originally Posted by seniorlady View Post
is it okay to cut the ground wire off where it comes out of the top of the chandelier?
no!!!!
Code05 is offline   Reply With Quote
Old 11-19-2011, 08:04 PM   #4
Rewards Points: 502
the fact you have to ask suggests you really need the extra bit of insurance the ground wire provides.
forresth is offline   Reply With Quote
Old 11-19-2011, 08:07 PM   #5
seansy59's Avatar
Rewards Points: 258
Buy 3 wire (Black, White, Green) stranded wire to your length at HomeDepot. Its about $0.50 a foot (the type thats used for powertools/lighting/extension cord/etc.) Buy a grounded male plug. Wire to the colors.
Black-Black, White-White, Copper/Green-Green
This way may sound ugly, and it is, but, I don't mean to scare you...........NEVER defeat the grounding on anything unless you want a risk of death or injury. The "grounding" is there to protect YOU!
seansy59 is offline   Reply With Quote
Old 11-20-2011, 11:08 AM   #6
Thanks Everyone! I'll do it correctly!
Old 11-20-2011, 11:57 AM   #7
Rewards Points: 58
Do you have a grounded receptacle? Is your house wired with a ground at every receptacle? Your question makes me ask. Do your receptacles (plugs) have three wires or two? Do you have conduit or cable (Romex) wiring?
Everyone is correct about the safety, but if you do not have a grounded receptacle to plug it into, you have no where to connect the ground wire. In this case you never cut it off. You fold it neatly back into the box unconnected.
Old 11-20-2011, 12:31 PM   #8
liscenced electrician
Rewards Points: 538
Maybe a picture of the light? Might be possible to do what you want and maintain a ground
jimmy21 is offline   Reply With Quote
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
