Ground Wire From Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 10:03 PM   #1
Ground wire from main panel
i cut a two inch hole in the wall to the outside of the house for the electrical cable i'm running the garage along with a 2 foot trench and noticed something about the main panel in the house. one of the ground wires leaving the ground bar to a rod outside in the main was definetly installed by some half rigging dumbass! the bare copper wire leaves the house in between two pieces of aluminum siding where they overlap each other. it's exposed and can easily be ran over with the lawn mover tripped over etc. beings i have the wall opened up i would like to fix this crap while im at it with the cable to the garage. so my question is what is the proper way for this wire to leave the house to the rod outside? can i just utilize the new two inch opening with the PVC pipping going the garage to run it through? it's conveniently right next to it.
bmorekid is offline   Reply With Quote
Old 01-09-2012, 10:25 PM   #2
Rewards Points: 2,516
Before anyone else asks I'll suggest a picture be put up possibly?
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
plummen (01-09-2012)
Old 01-09-2012, 10:29 PM   #3
i wish i could but i can't find the usb connector for my camera.
Old 01-09-2012, 10:31 PM   #4
Electrical Contractor
kbsparky's Avatar
Are there any other utility grounding wires attached? An inter-system bonding bar?
You have to ensure there is adequate access to that electrode conductor for proper bonding ....
-KB
Old 01-09-2012, 10:39 PM   #5
there is a bonding bar but not sure what that has to do with it. i just want to kill power to the panel, remove this existing ground wire and install it properly. it looks like someone drilled a hole through the siding just big enough to fit it through and is hanging out about a foot from the house where it connects to the ground bar.
Old 01-10-2012, 12:13 AM   #6
Julius793's Avatar
Run the ground wire in PVC
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-10-2012, 12:18 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Use the Shedule 80 aka thickwall PVC that will take a beating a bit more than what the Shedule 40 can do withstand it.
To OP just be aware not all big box store will stock Shedule 80 PVC espcally in small size that part you may want to scoot over to the electrique supply centre. they useally have something in stock.
Merci,
Marc
Old 01-10-2012, 05:25 AM   #8
Rewards Points: 1,494
The fat ground wire (grounding electrode conductor) from panel to ground rod can be run in any fashion that does not subject it to damage.
To a ground rod the maximum size needed for a GEC is #6 copper.
More Sub Panel Questions rdkng07 Electrical 6 05-25-2011 08:46 AM
Sub-panel selewis Electrical 23 02-21-2010 10:52 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
wire to a workshop jim c Electrical 11 03-02-2007 03:41 PM
