#1 |
Ground wire on jacuzzi pump?
When we had our house inspected before the purchase, the inspector noted the fact that the jacuzzi pump did not have a ground wire. How big a deal is that / how urgently should I fix it?
It's going to be marginally tricky in this case because the ground wire stud, assuming the motor has one, is on the far side of the motor from the access hatch. I'll probably need a mirror on a pole to see what I'm doing. Thanks! |
#2 |
Licensed electrician
Does the report say ground wire or a bond wire is missing? The ground wire should be in the cable feeding the tub.
A bond wire may not be needed, depending on the piping material used.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#3 |
E2 Electrician
Im betting it doesn't have a bond wire, and probably doesn't require one.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
# 8 awg min.
#5 |
Now that I look, it doesn't actually say anything about it on the report. I just remember the inspector mentioning it to me as we did the walk through. He said there should be a ground wire attached to the pump that runs either to a ground stake under the crawlspace or to cold water plumbing. He didn't see one and thought the terminal for it was probably on on the far side of the pump from the access hatch.
#6 |
A ground stake or rod would do absolutely nothing beneficial for the tub.
| The Following 2 Users Say Thank You to Jim Port For This Useful Post: | mpoulton (08-29-2012), stickboy1375 (08-29-2012) |
#7 | |
E2 Electrician
Ground wire on jacuzzi pump?Quote:
| The Following User Says Thank You to stickboy1375 For This Useful Post: | Jim Port (08-29-2012) |
#8 |
E2 Electrician
Just another H-I report gone wrong.
| The Following 2 Users Say Thank You to stickboy1375 For This Useful Post: | mpoulton (08-29-2012), Speedy Petey (08-29-2012) |
#9 | |
Licensed Electrical Cont.
Even if it were required, NEITHER of the two options he suggested is proper or necessary.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
| The Following 4 Users Say Thank You to Speedy Petey For This Useful Post: |
#10 | |
Lic Electrical Inspector
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#11 | |
E2 Electrician
I have seen some manufactures require a #8 from the motor back to the electrical panel, which I completely ignore, because that also serves no purpose and is just some jackass misinterpreting the NEC... The only requirement by the NEC is to bond the recirculating piping, if applicable, all tubs today are strictly plastic, so its a moot point.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by stickboy1375; 08-30-2012 at 06:42 PM. |
#12 |
I didn't state that it was required. I stated that "if" it was required. And I have neither the time nor desire to dig through all of my code books all the way back to the late sixties to find out.
#13 |
The thing with the all in one home inspectors is they hold up the sale of a house by their opinions. Buyers get leary.
| The Following 2 Users Say Thank You to bobelectric For This Useful Post: | electures (09-01-2012), Speedy Petey (08-31-2012) |
| Display Modes | |
| 240 Well Pump uses 12/2 Wire? | brgmgb | Electrical | 3 | 09-20-2011 11:26 AM |
| Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. | arca | Electrical | 17 | 03-28-2011 03:06 AM |
| What do I do with the ground wire? | Letty | Electrical | 1 | 03-17-2011 01:47 PM |
| Live ground wire in dryer | Retired sailor | Electrical | 10 | 05-04-2009 04:26 PM |
| swimming pool pump wire | steel | Electrical | 5 | 04-06-2008 09:35 PM |
