Ground Wire/Ground Screw/Metal Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 07:58 PM   #1
Hi All,
I have searched the forum and did not find the answer I was looking for. If this subject has been covered please direct me to the thread. Thanks!
I have a new light fixture with its own ground wire. The metal bar (hickey) has a grounding screw. The box also has a ground wire.
Every entry I read seems to have a different answer for proper grounding....here are my questions.
Q: If I am required to attach both ground wires to the grounding screw after securing with a wire nut, how?
Q: Another suggestion indicated it should be pig tailed with another bit of copper wire. If I do that, are all three wires then secured with a wire nut and then that single additional wire (the pigtail) is attached to the ground screw?
Q: I also read that I could make a "J" hook with the ground from the box, loop it about 3/4 around the grounding screw and then attach the ground wire from the fixture to the ground wire from the box and secure with a wire nut. Would that work?
Q: What if the box were plastic instead...do the same steps apply?
Thanks in advance!
Clueless in Colorado
tdtilton is offline   Reply With Quote
Old 05-16-2011, 08:30 PM   #2
Missouri Bound's Avatar
The grounding wire from the supply needs to connect to the grounding wire of the fixture. Whether it be wire nutted or connected to the box or the hickey isn't that important....as long as the fixture is grounded. Find the best way and implement it.
The Following User Says Thank You to Missouri Bound For This Useful Post:
tdtilton (05-17-2011)
Old 05-16-2011, 08:32 PM   #3
Licensed electrician
Rewards Points: 1,794
All the grounding conductors need to be connected together and to the bracket and box if metallic. Only one wire under the screw head. You can use pigtails to connect everything together if additional wire length is needed. You can use the 3/4 wrap method you describe.
You don't need to ground plastic boxes.
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
