Old 06-05-2012, 04:04 PM   #1
ground wire and box pigtail same size?
Can I use a #12awg to ground my air conditioner j-box and connect it to the #10 wire that grounds my air conditioner? My AC has a #10 ground wire coming through the box, but the steel j-box that feeds it is not grounded. I want to bond the ground to the box at the ground screw that is provided. It's not a question of whether it needs it, (it does), it is whether I can drop down a wire size on the pigtail.
David
n175h is offline   Reply With Quote
Old 06-05-2012, 04:07 PM   #2
Licensed Electrician
k_buz's Avatar
Technically...no
Location...Location...Location
Old 06-05-2012, 06:14 PM   #3
Lic Electrical Inspector
electures's Avatar
Has to be same size.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 06-05-2012, 06:26 PM   #4
You can't downsize the ground until over a 30 amp circuit.
bobelectric is online now   Reply With Quote
Old 06-06-2012, 12:42 AM   #5
Thanks guys,
Same size it will be
