Old 11-28-2012, 10:28 PM   #16
Ground Wire
Originally Posted by TTW
Very good thanks, is there any benefit to making it greater than 6 foot?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-28-2012, 11:11 PM   #17
JuzRick's Avatar
Ground Wire
Originally Posted by Billy_Bob View Post
Note: In rare situations there can be electricity on a water pipe or electricity on a ground wire!
So if you disconnect a ground wire - and are holding the ground wire in one hand and touching the metal pipe with the other hand, you could be shocked.
Best to "assume" the water pipe and the ground wire is "live" when disconnecting it.
So first turn off the main power to the house - If any appliance is "leaking" electricity to ground, that would remove the hazard.
And wear rubber gloves when connecting / disconnecting the ground wire. (In rare situations electricity can still enter through the city's water main or the electric company's "neutral" wire - from neighbor's malfunctioning electric/plumbing systems.)
There probably will not be any such problem, but a little safety is always a good idea!
Very informational!!!!
JuzRick is offline   Reply With Quote
Old 11-29-2012, 07:38 AM   #18
TTW
TTW's Avatar
Ground Wire
I don't think going more than 6 feet will give you any advantage.
Also, you can drive at an angle or bury if you have tough ground to get through or a ledge.
TTW is offline   Reply With Quote
The Following User Says Thank You to TTW For This Useful Post:
digitalplumber (11-29-2012)
Old 11-29-2012, 07:45 AM   #19
Ground Wire
I would look closely to see if one of the outlets is somehow connected to the pipe.
tribe_fan is offline   Reply With Quote
Old 12-07-2012, 10:57 AM   #20
Ground Wire
Thanks, there is not.
Old 12-09-2012, 10:35 PM   #21
Ground Wire
Do I need a special rated wire for this like for wet or corrosive conditions?
Old 02-16-2013, 10:11 AM   #22
Ground Wire
Followup...so we added a second ground rod as described, no issues.
But we ended up starting the repiping of this home with copper. The original stranded copper coming from the main electric panel is in the attic. Before I cloise up the ceiling, should I connect this stranded copper, which use to be connected to the galvanized, to the copper?
In reality, I think it was the original ONLY ground for the home, then we had the electricians re-wire and they added a grounding rod to the new bpanel.
Old 02-16-2013, 10:41 AM   #23
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Ground Wire
I would move the water pipe bond from where it is now and attach it to where it should be withing five feet of where the water main enters the home. And make sure the water heater has a jumper between the hot and cold.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-16-2013, 11:00 AM   #24
Ground Wire
That would be 30 feet away? so you want me to run from where the city entry point to the house is all the way to the electric panel?
Old 02-16-2013, 11:42 AM   #25
Licensed Electrician
k_buz's Avatar
Ground Wire
If you redid the panel/service, you must update the grounding. Including the water ground.
Not a fan of the new layout.
k_buz is online now   Reply With Quote
Old 02-16-2013, 11:51 AM   #26
rrolleston's Avatar
Ground Wire
250.68(C)(1) specifies
that only the first 5 ft of water piping entering the building
can be used as the point to make grounding electrode con-
ductor connections or as a conductor to interconnect ground-
ing electrodes.
This is assuming you have city water. You also have to run the ground wire so you can connect to both sides of the water meter and install a jumper to the hot and cold water heater connections.
Old 02-16-2013, 12:10 PM   #27
k_buz's Avatar
Ground Wire
It goes for wells also. You have to jumper the tank in that case.
The Following User Says Thank You to k_buz For This Useful Post:
electures (02-16-2013)
Old 02-16-2013, 12:48 PM   #28
rrolleston's Avatar
Ground Wire
Very true I should have made that clearer. Thank you.
Old 02-16-2013, 10:17 PM   #29
Ground Wire
They did, they installed one ground rod below the new panel.
Old 02-17-2013, 08:36 AM   #30
Ground Wire
TTW....That book looks to be very informative to a dyi person....Could you share the name of it.....Thanks
movin-on is offline   Reply With Quote
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
