Ground Tripped Florescent - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2010, 01:38 AM   #1
Ground tripped florescent
I installed a four-lamp florescent light from an outlet controlled by a wall switch using wiremold. I used 14 ga solid wires, black, white & green. Got every thing installed, flipped the switch and tripped the breaker. Making a long story short, I removed the green ground from the wall outlet green screw and bingo every thing worked fined. Why would the ground make the breaker trip? The outlet was grounded, all I did was run a ground wire (green) to the florescent groung screw. Help!
Maximo is offline   Reply With Quote
Old 05-15-2010, 08:02 AM   #2
Rewards Points: 1,442
The fixture could have been defective. Or you pinched a wire in the Wiremold channel. Been there done that.
Turn the power off and use a multimeter (or ohmmeter). Disconnect both black and white leads down at the switch. There should not be continuity between the frame of the fixture and either the now loose white or black lead.
When the ground wires are properly connected, shorting hot to either neutral or ground should trip the breaker.
The Following User Says Thank You to AllanJ For This Useful Post:
Maximo (05-15-2010)
Old 05-15-2010, 09:26 AM   #3
Coffee Drinker
walkerj's Avatar
You have a short somewhere in your wiremold or fixture.
If you remove the wiring you installed there is probably a nice little arc mark.
If you have removed the ground, the metal parts of your fixture are now energized
walkerj is offline   Reply With Quote
The Following User Says Thank You to walkerj For This Useful Post:
Maximo (05-15-2010)
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
