Old 01-12-2013, 10:19 AM   #16
is ground screw on light switch necessary
Originally Posted by Red Squirrel View Post
TBH I never really bother, as long as the box is grounded properly the switch will also be grounded. Though I think the point of it is when the switch is not screwed into the box (ex: middle of construction) then it is still grounded.
That is good to know, probably why I never done it myself. Lot of the stuff I've learned was from just seeing how others did it when I took something apart.
This is only true because even canadian plastic boxes have a metal bonding strip for the mounting screws.
US boxes have no such provision., if the ground is not connected to the device, the device is not grounded. Unless you're using an all metal box.
Techy is offline   Reply With Quote
Old 01-12-2013, 01:19 PM   #17
Originally Posted by n0c7 View Post
If you're in Canada you're in luck, no grounding of light switches required.
Not in Ontario either! This is a rule concocted by engineer's under pressure to keep turning out product to justify their high wages.
Old 01-12-2013, 04:48 PM   #18
Wire Chewer
Red Squirrel's Avatar
Oh yeah definitely a different story if using a plastic box. I was thinking all metal ones. Those are more common so I've always used them.
Any electricians? Question about a DC switch. Switch is on ground wire(s). Deck Electrical 22 01-14-2012 05:21 PM
Spark Connecting Ground on light fixture RonaldD Electrical 12 01-10-2012 08:58 PM
Light switch - Taping into ground wire ok? SimpleJack Electrical 2 08-15-2011 08:04 AM
Wiring lights in new construction Mi Feller Electrical 38 06-10-2010 12:24 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
